ls1 harness connector part numbers
Old Jan 20, 2011 | 12:44 AM
gwf7782's Avatar
Default ls1 harness connector part numbers
Im looking for the delphi part numbers for these connectors:
(all for 2000 camaro ls1), just the connectors not the pigtails
MAP sensor
Camshaft position sensor
Knock sensors
Crankshaft position sensor
O2 sensors upstream only
Fuel injector connectors
Coil connectors
IATS – intake air temp. sensor
IAC – idle air control valve
TPS- throttle position sensor
ECT-engine coolant temp. Sensor
MAF-mass air flow sensor
VSS-variable speed sensor
Transmission plug-multi pin connector
Thanks for your help.
Old Jan 20, 2011 | 01:29 AM
LS1MCSS's Avatar
You can get all of those right here a lot cheaper than from a dealer.
http://tpiparts.net/98_02_camaro_harness_and_wiring?b=1
Old Jan 20, 2011 | 11:09 AM
gwf7782's Avatar
I just need the connectors not the pigtails and that site doesn't give me the Delphi p/n.
Old Jan 20, 2011 | 11:23 AM
Pocket's Avatar
http://www.thirdgen.org/techboard/lt...erchanges.html
Its not complete, feel free to post up the missing PNs
Old Jan 20, 2011 | 01:34 PM
gwf7782's Avatar
Thanks that link is very helpful.
Old Jan 25, 2011 | 11:16 AM
LS2 67GTO's Avatar
here see if this helps.
http://www.compnine.com/index.php?r=...de=C&year=1999
Old Jan 25, 2011 | 11:47 AM
LS88FoxBody's Avatar
EFI connection should have them all..
