LS1 Swap BLOWN HEAD GASKET?
Old Jan 22, 2011 | 04:22 PM
danielburko's Avatar
Default LS1 Swap BLOWN HEAD GASKET?
Hey Guys,
I just took a video of the car because there is an awful lot of white smoke coming from the back of the car at idle and when revving.
It was on a cold start. It ran for about 10 minutes, brought temp to 150. Its about 25 degress out right now so I am not sure here.
It left a little puddle of water under each tail pipe.
I also just installed a new exhaust system, headers, all the way out the back. I know the headers are going to burn off whatever is on them for a bit, but it just seems like a lot of smoke to me.
It doesnt hang around long, maybe 3 seconds and the dissapears. It doesnt smell like anti freeze at all, and the car runs great, no high temps.
I didnt do the test yet with the blue dye. I wanted to see what you guys thought? Is it something to worry about?
Please look at the video for me.
http://www.youtube.com/watch?v=i-JP2_e57ek
Old Jan 22, 2011 | 05:22 PM
leon phelps's Avatar
Run the car on the road for a half hour then look.
condensation in the exhaust and 150 is not getting the engine hot. gauges are not always right on, so you could be at 130.
Old Jan 22, 2011 | 05:38 PM
I think the gauges are gonna be pretty close there all brand new autometer cluster full sweep gauges. Ok I'll try that.
Old Jan 22, 2011 | 05:48 PM
jim ravencraft's Avatar
Smile
hi,
i would spend the 45 minutes to do a compression check. write down the numbers on each cylinder. you can also perform a leak-down test. check the oil dipstick for tell-tell signs???
of oil and water mix/not always present. i would not drive the vehicle until i was sure of the issue. you do not want to risk a cracked head or block. smoke is usually white on head gasket and coolant issues also at start up. blue/gray smoke is also common for oil consumption/black smoke injector-carb-ignition etc. if you have a modulator valve it can also create the white fog. i hope this helps you with the issues..............have a blessed day.
jim
Old Jan 23, 2011 | 08:43 AM
Old Geezer's Avatar
As mentioned, it's cold weather condensation..................
Old Jan 23, 2011 | 01:37 PM
ls1nova71's Avatar
X2. If that's a blown headgasket, then every car I have ever driven in the winter has had blown headgaskets. You said it's 25 degrees out, so I'm guessing you're from a warmer climate originally and have never dealt with below freezing temps before, so I wouldn't worry about it if I were you. Plus, you would have to have two blown headgaskets because there's steam coming from both sides.
Old Jan 23, 2011 | 03:07 PM
Yea. Its cold out here man. I thought it was just condensation and the brutal cold temps. Thanks for the input guys.
