Anybody used a Windstar radiator?
Setup is 69 GTO convertible with an LY6/T56.
Thanks
Jim
F-body fan and radiators are a solid backup if I can find them
HTH
We had to show ford how to use em, since their fans out last most of the windstar motors...
Truth be told all of these guys running around talking about the data info, but I am the one who got the info and its funny, how the word has traveled...I posted that data back in 09 and it has finally made it over here by a guy who copied my post and pasted my post. The key distinction that guys are leaving out is that the 4000+ cfm is from Dorman data test tech... That does not necessarly mean that a factory unit or other brand will flow 4000+cfm..... The only verification of 4400 cfm+ was done and recieved by Dorman. I stayed on the phone with the Dorman tech for 1-2 hrs as he went through all of the test files.
Was posted back in 2009 and has traveled across the web....lol
The fans are $106 at Rock Auto, but I am sure they can be found in the junkyard or salvage yard for less........
Test Results:
2000 Ford Windstar Fan Assembly
left fan: 340ml= 13.3inches
right fan: 390ml=15.3inches
left fan: 60.3cmm=2129.193cfm
right fan: 64.4cmm=2273.964cfm
this was rated at 1935 RPMS
4403.157 cfm total......
ml= milliters
cmm= cubic meters per minute
cfm= cubic feet per minute
conversion from cmm to cfm done by cmm x 35.31= cfm
Only $106..... dorman 99-03 ford windstar fan 6 blades but bigger fan blades.
The 94-98 dorman fans has 8 blades but smaller blades. I don t know if the having more blades are better or if its the design of the blade thats better.......
So as I said the data was from Dorman and the fan's motors and system they use. I cannot account or know what the factory or other brands would do.
I will say with the Dorman 2000 Windstar fans I have, they cool very quickly. When they do kick on, they drop the fans 10-15 degrees in less than 20 seconds.. Plus I have a alum radiator that was big enough to keep a BBC around 160-170* without the fans on. So
I am sure other factor fans will work as well.
Bozz
