stock ls1 ac compressor block? need help
Old Jan 29, 2011 | 05:52 PM
70c10's Avatar
Default stock ls1 ac compressor block? need help
has anyone modified the stock compressor block? I bought a block from docsblocs but it wont work with my setup. The stock block will work but I need the suction tube off the block turned 180*. It looks like the 5/8 alum tube is slip fitted into the block and then soldered or welded. Is it possible to heat it up and spin it around or pull it out and then re weld it or is it pressed into the block.
