FAST 102 flip - modification
Old Jan 31, 2011 | 10:14 PM
CharlieC's Avatar
Default FAST 102 flip - modification
Have a need/desire to mount a Fast 102 upside down on my Marcella manifold to put the linkage on the drivers side.
One issue which appears in doing this, is it will put the TPS up on top pointing forward which would look like crap. I'd like to re-clock the TPS sensor to the original orientation of pointing down. I assume the sensor would be aware it's 180 off, or can I get lucky here in that it wouldn't matter as the sensor just knows where "closed" is?
How does the throttle assembly come apart if I wanted to pursue making a new shaft that changed the end where the TPS sensor mounted to match the new clocking?
Thanks,
Charlie
