best option for lsx sn95
anyways i've owned an sn95 before, and i obviously own an lsx. so i'm not a noob to either platform. however i've never really looked into lsx swapping a stang. first off i know i need an AJE k-member with the MU-30 mounts, and an MU-7061 crossmember for the th400(just by looking at the website). but my question to you guys is what other ls swap specific issues would i run into? headers? steering? driveshaft? wiring? i think if it's one thing that scares me away from a ground up build it'd be wiring.
Steering - Flaming river rack if you're losing the p/s.
driveshaft - Do a search here, all it takes is a specific u joint, you re-use the mustang driveshaft.
wiring - you can buy a standalone harness from a variety of vendors or board members OR have speartech rework a stock harness for you.
steering- i'm assuming a direct fit onto the aje k-member?
driveshaft- by re-using the stocker would it handle the power a modded 6.0 would be putting out? in my case the car would be on a trans brake with slicks. so maybe an aftermarket would be best for me?
wiring- pardon my ignorance for wiring, but i assumed that i would use a GM PCM and modified harness. is that not the case? also i assume that all the wiring for lights, fan, non motor related stuff stays ford? and what about wiring and plumbing for the fuel system? would all the ford stuff get trashed for a custom ran system?
steering - yes, direct fit to the aje k member with the stock rack or a variety of aftermarket pieces.
driveshaft- not sure what the capacity is for the stocker, an aftermarket one may be required
Wiring - your assumptions are correct. You can use a modified gm harness or have a new one made up. Either would operate as a stand-alone. other vehicle wiring (lights, interior...) would utilize the oem ford stuff.
99mustang5.3 is 100% correct about 96gtdan's build thread. Lots of documentation and very helpful. Its about 12 pages and well worth the time it takes to read every entry. Here is the link
https://ls1tech.com/forums/conversio...-lsx-swap.html
If you read the dynatech website, it says you must you a tube K-member and tubular control arms.
btw read 96gtdan's thread, it's got some good stuff in there. also i found another thread that had a lot of wiring diagrams and a fuel system layout that would be super helpful. i'll find the link to that one later and post it.
btw anybody have any insite as to what options i should choose when buying a th400? trans brake and manual valve body are both priorities. and looking at TCI's website they offer a million different combo's for these trannies.
then use a speartech for the engine (if you are keeping it efi) or the MSD 6010/6012 if you are going carbed.
You will probably save 50 lbs pulling all of the ford wiring out
Using Dynatech headers, AJE kmember and mounts and the engine pretty much falls into place.
I had a driveshaft made for my car and it was very reasonable in price.
My car has a stock 8.8 /3.73s and I haven't had any issues yet although it is being built this winter.
Steering isn't too bad if you just loop the lines and don't run power steering, or you can buy the flaming river manual rack
http://www.currentperformance.com/
Rich
