motor mount adaptors
What is next to figure out is the Height of the engine to sit. This is due to pan, crossmember, Accessories, frame and other areas of contact.
Warning, the higher of the front of the engine many cause problem and more chances that the trans might come into contact with the firewall/trans tunnel when trying to get your engine tilt angle.
You change the height by using shims, spacers, different engine Mount (tall/narrow or short/wide) and Frame stands (Also T/N or S/W). I used a combination of T/N engine mounts with mod'd S/W frame stand to get the height I needed for my Chevelle.
