help!
Old Feb 12, 2011 | 12:25 PM
kaotic_ws6's Avatar
Default help!
ive searched around and found a few possible leads but wanted yalls opinion, im doin a 68 swb c10 with a ls1/th400... ive got most off my stuff wired up but wanted to check to make sure it would run, BUT it will run for a 1-3 sec then shut off. ive got the blue VATS wire hooked up to the bcm for the fuel so idk why that would be a problem, (using vats because i kept my camaro column and key) i dont have my o2's hooked up or any of my gauges (camaro cluster) but im not sure why that would matter, idk what could be wrong. 99 cluster pcm and harness. PLEASE HELP.
Old Feb 14, 2011 | 05:46 PM
kaotic_ws6's Avatar
no one??
Old Feb 14, 2011 | 07:14 PM
deuce4935's Avatar
Still sounds like the vats is kicking in.
Old Feb 14, 2011 | 09:18 PM
rotor vs. piston's Avatar
I agree, something related to VATS if it's so consistent to cut off ~3 seconds.
