Connector 220 Pin C
2002 LS1 from a firebird. Trying to figure out what exactly this pin is and how to wire it. From the word document I have....
"C. Power supply to TCC stop lamp switch, not used in 6SPD or if your car already has a TCC stop switch. If your car does not have a stop lamp switch then use this to feed power to feed the switch."
I have a 4l60e transmission. Putting the engine into a 65 Impala.
I know I posted this before, but I got six different answers in the post and am still confused.
I am still also confused to what is a TCC stop lamp switch.
Any help would be greatly appreciated.
I have made a relay to unlock the torque converter when the brake pedal is depressed. This circuit is always feeding power to the converter until the brakes are pressed then the circuit is broken. This other circuit is on the same 220 connector, lettered D.
From what I have told you, it seems to me that I do not need to use pin "C" correct?
