ls swap fuel pump relay problem
The red #9 pin on the ecm should give a ground sig. to turn on the relay right??
As its wired now for some resone I have 12v on the # 9 pin with ignition on and if I turn off ignition the 12v goes away.
So I was thinking I just needed constant ground for the fuel pump relay and just use the pos. off the #9 pin but I can not get hp tuner to control the relay by manually on/off for the fuel pump
PLEASE help this is confusing me
That #9 is a 12v coming from the PCM, so ground the Relay, and the PCM will energize it. It should stay hot for 3 sec if the Engine isnt running.
but ether way the #9 pin stays hot as long as the key is on, If I new the rev limiter would still cut fuel at a set rpm I would wire it up using the #9 pin as my hot side for the relay
but I dont think it will cut fuel for a set rpm
thanks for your input
