will my stock gauges work with the LS1?
Old Feb 15, 2004 | 02:49 AM
tomj1404's Avatar
Default will my stock gauges work with the LS1?
I was just wondering if it is possible to make my 1982 corvette gauges work with the LS1. I'll probably buy new gauges later anyway but If I could use the stock gauges for a while without having to spend a lot of money that would help out a lot with this swap I'm planning.
Old Feb 16, 2004 | 10:04 AM
70 LS1's Avatar
Conversion master
Some will and some will not.
Speedometer - No, unless you convert the trans to have a mechanical speedo output, or you buy an adapter that takes the electric output and converts it to drive a mechanical speedo.
Tach - No. The tach output from the computer operates on a lower voltage and frequency than yours. It requires a 4 cylinder tach.
Oil Pressure - Yes. On your engine there is a small plate just above the oil filter. On the corvettes this was used for oil temp and on the F-bodies this was just a blocking plate. You can take the camaro one and drill and tap it for 1/8" pipe thread and run a sensing line to your oil pressure.
Fuel gauge - Yes. As long as you are still using the 82 vette tank and sender.
Water temp - Yes and No. You can buy a sending unit from autometer for their electric water temp. (Don't know the part #) Place it in the passenger's head right near the aft plug. There is a little plug there now that is 12x1.5 threads. You can buy an adapter or drill and tap the plug to 1/8 pipe to make your own adapter. The water temp will be a little off, but it will track and show trends which is what you really care about.
Voltmeter - Yes. I have an ammeter in mine and it did not work correctly, but a voltmeter is a voltmeter.
Clock - Probably not. It is a corvette.
hope this helps.
Old Feb 16, 2004 | 03:53 PM
Scooter70's Avatar
I know my clock has never worked as long as I've owned the car (10+ years). Then again, neither has the speedo.... or odometer..... or tach..... owning an old car is fun!
Will my Autometer 3" column mounted tach work?
Old Feb 16, 2004 | 04:05 PM
70 LS1's Avatar
Conversion master
My clock has never worked either. In fact, the only gauges I have working are fuel, water temp and oil pressure. I am saving up for a complete set of autometer phantoms, but I also want to wait until I redo the interior. I really don't want to rip my dash apart more than once. And I can live, temporarily, without the others. I guess I coiuld just use the rev-limiter as a tach.
As far as your autometer tach, as long as you can select 4-cylinder on the back it should work. This link tells you how to make it work.LS1 Autometer Tach.
Old Feb 20, 2004 | 02:01 AM
tomj1404's Avatar
Can I use get a corvette plate that already has a hole for the sender? I was thinking that I would put the oil temp sender there and put the pressure sender where the stock one is
