LQ4 questions
Old Feb 28, 2011 | 11:43 PM
slownova73's Avatar
Default LQ4 questions
ive heard that the LQ4 can be bolted to any early model transmission, such as a TH350,without the spacer kit, is this true?
Old Mar 1, 2011 | 12:28 AM
gofastwclass's Avatar
Only some of the early (1999, 2000 so I am told) engines had a long crank flange. According to the documentation I have, most of those engines had iron heads. GMPP sells a spacer just for this occasion (that works on all Gen III engines) which is detailed in my Thunderbird build topic in my sig. Other people make one as well but that part and it's six accompanying bolts have been in my car without issue for over 15K miles.
Old Mar 1, 2011 | 01:15 AM
slownova73's Avatar
ok cool ,thanks man!
Old Mar 1, 2011 | 02:21 PM
Bo185's Avatar
If it has the flat flex plate and is the later 2001 motors it will have a spacer already on the crank side of the flex plate. Then just match up the holes or you might have to drill new as the flat flexplate has six bolt holes.
Old Mar 1, 2011 | 11:44 PM
slownova73's Avatar
so either way would require some work, ok thats cool, just seeing what my options are
