LQ4 into a 1968 chevelle question
You can use all of the truck accessory drive if you simply swap the PS pulley. There are several threads in that regard. You can use the truck AC compressor and bracket with a bit of minor surgery to the bracket.
I used Dougs mount kit with tall Energy Suspension mounts & Dougs long tube headers. The trans crossmember may need a bit of modification to clear exhaust. I am also using an Impala SS fuel tank.
I recommend that you change the oil pan right now since the LH8 will hang too low. I used a Canton pan and pickup along with their oil filter mount.
Overall so far so good.
http://cgi.ebay.com/ebaymotors/E171-...Q5fCarQ5fParts
