Vacuum source for vette FPR
Old Feb 15, 2004 | 08:31 PM
bad86z28's Avatar
Default Vacuum source for vette FPR
Does anyone know where to tap into for a vacuum sourve for the FPR that comes on the '97 vette fuel rail? I have heard that it comes from in front of the TB. Is that true? It seems like it would be using the wrong type of vacuum. Shouldn't it use manifold vacuum? Thanks for the help.
Old Feb 16, 2004 | 09:52 AM
70 LS1's Avatar
Conversion master
The 97 vette FPR doesn't use vacuum. It uses barometric or atmospheric pressure as a reference and has a sensing line that senses pressure outside of the engine compartment to get a better reading.
Old Feb 17, 2004 | 04:44 PM
bad86z28's Avatar
Are you saying that I just hook a line to that vacuum port on the regulator that is on the fuel rail and just leave it open? Do I have to situate it so the line is outside the engine compartment?
Old Feb 17, 2004 | 06:09 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
You don't even have to put a hose on it at all. It will work just fine left open.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Feb 17, 2004 | 07:50 PM
bad86z28's Avatar
That's just wierd. Any FPR I've ever seen has had a vacuum reference from the manifold. Whatever, makes it easier for me. Thanks.
Old Feb 17, 2004 | 08:19 PM
70 LS1's Avatar
Conversion master
Don't think of it as a vacuum reference. The LS1 is different in that it runs a constant fuel pressure regardless of engine load. Because of that it needs a constant reference for its FPR. Post 98 vettes don't even use this type of regulator.
The vacuum sensing regulators need to vary fuel pressure with engine load, i.e. vacuum.
Old Feb 17, 2004 | 08:27 PM
slow's Avatar
the ls1 is a stupid system 58 psi static.
the normal "vacuum referenced" type is nice, as you get a constant differential between the intake, and the rails, great for tuning.
the 58 static of the ls1 is alrightunless you go forced induction, and then your injectors get smaller as you get into boost (NOT GOOD)
Ryan
Old Feb 17, 2004 | 10:37 PM
bad86z28's Avatar
So basically, that open port just gives it a constant vacuum to provide a constant fuel pressure. I guess that makes sense. Come to think of it, I don't recall seeing a vacuum port on the '98 and later vette regulator/filter assemblies.
Like I said before, that seems odd, but it makes sense. I guess I'll just leave it open. Just out of curiousity, what would happen if it was hooked to manifold vacuum? How would it affect the fuel pressure, if at all?
Old Feb 18, 2004 | 01:36 PM
John B's Avatar
Moderator
To answer your question the OEM location for this connection is a hole in the rubber bellows just in front of the TB and behind the MAF conenction. This is how mine is set-up (I just poked a hole, inserted the tube with a dab of silicone) and it now mimic's the OEM set-up (less the silicone!).
Old Feb 18, 2004 | 04:23 PM
Speartech's Avatar
If you were to hook it up to vacuum it would act like any other vacuum referenced regulator. The pressure would be lower at high vac. and higher at low vac. The problem is that the injector flow tables in the PCM are set up specifically for the constant pressure. If you were to hook it up to vac., then you would need to go into the fuel table and rescale the flow rate for a vac. compensated regulator.
__________________
www.speartech.com
Old Nov 16, 2004 | 11:14 PM
GrannySShifting's Avatar
sorry to drag this up... on a LT1 car, with LS1 engine vette ealry rails.. is the reg rail mounted? could I hook it up to a vacuum source, plug stock fuel lines into it and go?
Old Nov 17, 2004 | 06:46 AM
Speartech's Avatar
Yeah, or just hook it all up and skip hooking up a vacuum line and be even better.
The 97-98 Vette fuel pressure regulator is rail mounted but not vacuum referenced.
__________________
www.speartech.com
Old Nov 17, 2004 | 08:45 AM
do you guys have any clean 97 rails/regs forsale? Or knwo where i can get some
Old Nov 17, 2004 | 09:27 AM
Speartech's Avatar
No I don't. In fact I really don't even look for them anymore. We use the Corvette filter/regulator for most of the swap stuff anymore. You could use that and just plug the LT1 feed and return into the filter; and then just fab 1 line from the filter to the LS1 fuel rail.
__________________
www.speartech.com
Old Nov 17, 2004 | 10:32 AM
Id rather be abble to use all of my existing stuff. i assume your talkign abotu the 99-up Vette fuel filter/reg peice?
