LS2 in 07+ 1500
Old Mar 5, 2011 | 06:33 PM
ItsJasonThomas's Avatar
Default LS2 in 07+ 1500
I was wondering if my LS2 i have sitting around will bolt right into a 4.8 or 5.3 Chevy 1500 pick up? Or what is needed, and is it even possible in a V6 1500?
Old Mar 6, 2011 | 12:37 PM
Jimbo1367's Avatar
yes it will bolt into either.(4.8/5.3 OR v6) It would be alot easier to start with a 4.8/5.3
Old Mar 6, 2011 | 01:24 PM
What would be needed in a v6?
Old Mar 6, 2011 | 04:21 PM
Bo185's Avatar
If the truck is a GMT900 and a V8 already its a bolt in swap for the LS2. If its a V6 then you need alot more mods to get it to work.
Do some searching on the truck site as the V6 swap has been done there before
http://www.performancetrucks.net/forums/
Old Mar 7, 2011 | 07:42 AM
jmilz28's Avatar
Just check to make sure the reluctor rings are the same...everything else will be easy.
Old Mar 7, 2011 | 01:01 PM
Bo185's Avatar
That's a good point some of the LS2's are 24x and won't work easy with the new trucks.
