oil pressure sensor adapter
Old Mar 8, 2011 | 12:08 PM
crosstraining's Avatar
Default oil pressure sensor adapter
I was putting my Speed Hut gauges in my LQ9 this weekend, and the oil pressure sensor is a different thread size. Does anyone know where I can get an adaptor? Hopefully a longer one, because the new one is huge & will not fit. The water temp is also a different thread size, and I need an adaptor for that too. My car is at my Dad's garage 30 minutes away. I will try to get some pics of them tonight.
Thanks,
Brandon
Old Mar 8, 2011 | 12:10 PM
mikezohsix's Avatar
Jeggs and similar speed shops have them on line. A local speed shop got me an adapter in a day for less than $10. I think it was made by Autometer.
The thread is 16mm as I recall, and the adapter changes it to 1/8 pipe thread.
Old Mar 8, 2011 | 12:27 PM
Randy WS6's Avatar
the LS style oil pressure unit theads are 16mm x 1.5
Old Mar 8, 2011 | 01:25 PM
bczee's Avatar
If your not using the OEM gauge/sender.. take it, break the top plastic off, take the bottom alum part, drill and tap to the thread size of your Speed Hut sender.
cost? = priceless
Old Mar 8, 2011 | 01:27 PM
cost? = priceless
This could be a possibility. Thanks
Old Mar 8, 2011 | 01:49 PM
bczee's Avatar
I have used this on my chevelle.. as long as you have room your ok. if your sender is large. and space is tight. could be a issue. but at lease you go options.
Also you can use the bypass plate above the oil filter, if it is not be used for an oil cooler. The F-Body ones are good cause they have a cast boss to drill and tap.
I use both. one for pressure gauge and the other for my fav !... the "Idiot Light" LOL ! I just used the oem for the body/gauge in one of the locations.
Old Mar 8, 2011 | 03:42 PM
zipster's Avatar
cost? = priceless
Now that is what I am going to do!!!!
Old Mar 8, 2011 | 03:47 PM
dville_gt's Avatar
Old Mar 8, 2011 | 03:57 PM
RATBOX's Avatar
Just did this, worked great.
Old Mar 8, 2011 | 03:59 PM
nissan 570sx's Avatar
cost? = priceless
That's what I did for my Autometer oil pressure gauge. Works great.
Old Mar 9, 2011 | 06:22 AM
Pop N Wood's Avatar
Here you go. For $7 you get oil and water temp adapters without having to destroy a $50 oil pressure sensor.
http://www.google.com/products/catal...d=0CCgQ8gIwAg#
Old Mar 9, 2011 | 10:52 AM
Originally Posted by Pop N Wood
Here you go. For $7 you get oil and water temp adapters without having to destroy a useless oil pressure sensor.
fixed
Old Mar 10, 2011 | 02:13 PM
greasemonkeychef's Avatar
Autometer part #'s to adapt electric gauges to LS based engines.
Oil pressure switch: #2268
Coolant temp sensor: #2277
These are for the for electric gauges. Part numbers change for full sweep and half sweep. If you go to the website it explains.
Old Mar 11, 2011 | 01:16 PM
I ordered the coolant temp sensor: #2277 @7pm & Fed-ex was at my door @ 2pm the next day. Delivered in less than 24 hours, and I got a free hat. Excellent service! My Dad got an oil pressure sensor adaptor at a local parts store. I have not seen it yet.
DSCN0378.jpg?t=1299870623
Old Mar 11, 2011 | 02:49 PM
dville_gt's Avatar
You will also need a shorter sensor:
https://ls1tech.com/forums/12040069-post22.html
Old Mar 11, 2011 | 07:08 PM
damn...
Thanks
Old Mar 11, 2011 | 07:24 PM
RATBOX's Avatar
I just tapped a hole for an autometer electric sender on the hotside of the water pump, where the hot coolant goes out to the heater core. Easy enough.
Old Mar 12, 2011 | 10:50 AM
Gray86hatch's Avatar
One thing I have started doing it running a remote manifold for my oil pressure sending units/gauges
I use a braded -3 line to connect the engine to the remote manifold with the warning light, gauge and fuel pump shut off.
1 line hook up to the engine with the Autometer addaper the manifold is hidden on the fire wall somewhere.
Tim
Old May 29, 2014 | 05:18 PM
sirhk100's Avatar
Does anyone know what this link originally was directed towards? I'm fumbling thru my first experience with a LQ9 and want to hook up a oil temp, oil pressure and water temp autometer gauges. I already have the gauges, need to get sending units and figure out where to slap them in at.
