427ci LS1 project Help Please!
I already have a good header and exhaust setup from GMMG. I want a decently aggressive cam with heads to match. A noticeable lope, but not extremely aggressive where it sounds like it'll stall at any given moment. I'm thinkin in the ballpark of 8-8.5:1 DCR. Should I be looking at pistons for the LS7 for this job? I want a final bore size of 4.125 and with a stroke of 4.0 that will give me the 427 I want, but how do I determine which pistons and all to get? I want to be in the 600+ range in HP and torque N/A. I know I'll need a better fuel pump and injectors but how big should I go on the injectors? I'm thinking FAST LSX Manifold with the 92MM TB. Any suggestions would be greatly appreciated! I don't need the highest quality stuff I just want some experienced opinions, maybe some that have a similar setup, on what would be best for me. Thanks in advance for your input!
Why do you want your compression so low? 8-8.5?? I haven't calculated mine yet but with the 32cc dish pistons I think its still pushin close to 9:1
