lsx swap ?
Old Mar 22, 2011 | 09:13 PM
91_rs-teal's Avatar
Default lsx swap ?
Hey I'm looking at doing a swap in my Camaro and I know i need to find a fuel line with a return but thats hard to find. also a cable style TB
im looking into goin a little cheaper 5.3 swap and i found a intake,tb, rail and inj. off a 01 truck.
will this plug in? will this work with a ls1 harness? has anybody done this?
i have a SS hood so i have the clearance for the taller intake
Old Mar 22, 2011 | 09:34 PM
RPD_Vette84's Avatar
wow lots o questions there. the intake setup off the truck most likely wont work even with your SS hood. There has been people that have made it fit but its take some work. the ls1 harness would work with that stuff but you need to change the injector plugs or buy the adapters. check thirdgen.org for this stuff theyll help you out there. Im about to start the same thing.
Old Mar 22, 2011 | 09:51 PM
82lsx cutlass's Avatar
Well the fuel line you can find it WWW.paceperformance.com under lsx and its a regulater/filter with the fittings you need.
