New mechanical speedometer drive solution
I keep changing the speed of the test spedometer. Its now at 50,000 miles. I took it apart to inspect the coupler, everything looks absolutely perfect.
We did do the first test run on the electronics. Had a couple of hurdles, got them sorted out and looking to test again. This is coming along pretty well. Just wish I started it in fall, not early spring.
Keep up the good work Tim.
I still like your version better.
They told me to send them the box and speedo to check it and they did repair my speedo and sent the box back and it just didn't work right still. I think it needs a straight path for the speedometer cable, mine had a very mild 45* bend. I ended up removing the tailhousing off my T56 and had it modified for a speedometer cable and used my old stock cable and it works great, I paid around $350.00 for the conversion and freight. You might want to search for some reviews on the cablex it seems about 50-50 on satisfied and non satisfied users of the cablex, who knows you might be a satisfied customer.
But back to your k.i.s.s. the old tried and true speedometer cable works just fine, and I was able to keep my stock speedometer and dash as that was a major concern for me.
I give these guys props for their ingenuity and tenacity, anytime you can have multiple solutions for a problem the end user wins, as what works great for one person in a certain application may not work for someone else.
I've been using the cable-x for a couple years now, and it's alright... I guess. This set up looks much better.
The Cable X Box is JUNK you need to talk to some of the guys running them and you will see what i am talking about.
If using the speedo out put for your LS computer it's switches 6,7,9,11
If I don't break down and buy $800 worth of Autometer stuff this would be amazing.
The cable x seems like a huge pain in the *** and still have issues. I would rather not have a speedo than drop $300 on something that "kinda works"
