Injectors not pulsing
I also plugged in my old PCM. It seems to do the same thing. It fires all 8 for a few seconds & then peters out, like not all are firing.
Any other ideas for only 2 injectors not consistently firing?
The plugs are all snug & look correct.
Also, I am getting a code for the accelerator pedal position system.
Jon is this PCM for a DBW set up? I'll PM you too.
I did not get this code with the old PCM.
if you don't want to go to all the trouble of moving injectors you could always just swap a couple of injector connectors and see if they fire...won't run a smooth but should still run.
Just some thoughts hope they help.
Thanks Anticarb
The wiring to both injectors are good. I checked continuity to the PCM & that was good. I also checked the power to the injector & it was 12v. I swapped an injectoer that was woking with 1 that was pulsing & that made no difference
So, I think I have ruled out the injectors & the wiring. What does that leave? I think that can only leave the PCM, but I can hardly believe that I have 2 bad PCM's.
Any other ideas?
Thanks
Check post dates....
. I will try that this coming weekend. The car is not at my house, makes for frustrating work.
