Car Built For Mileage - need input
Old Mar 31, 2011 | 01:14 AM
gofastwclass's Avatar
Originally Posted by Bo185
The AFM (DOD) is a waste of money and time for a small 1-2% increase in MPG. It only works on the hwy at speed and with that high of a rear ratio it may drop out of 4 mode most times although you can tune it as well.
Just get a Gen III 4.8l and T56 and stay out of the pedal. Reduce weight and it should do OK MPG wise and not break the bank.
I politely disagree. You mentioned the key word - the tune. You have to remember the OEMs are saddled with rules, and issues we in the custom car world don't have to worry about. OEM cars (even sports cars) are supposed to be squishy, quiet, easy to drive and comfortable while passing emissions, lasting for 100K and so on. They can't vibrate, make noise or have a harsh ride and all this has to be done through cats and a quiet and restrictive exhaust. If you are willing to eliminate some of the factory limitations I feel 100% sure there is more power and economy to be gained without opening the engine. Think of how aggressive you could be with a stock engine and a tune - the tune and removal of unnecessary trash will take you a long way if you don't have factory limitations to worry about.
Old Mar 31, 2011 | 01:28 AM
71ANTICARB's Avatar
All in all it seem that doing a swap just for mileage is not really practical. But if you really enjoy the car and just want to make it more "driveable" it does seem that there are a few options.
Old Mar 31, 2011 | 09:03 AM
Wimimc's Avatar
i've been looking into it and i think i'm going to go the 2.2L 5 speed S10 route. it has about the mileage i'm looking for, plus with bolt ons it gets a little more, its a truck so i can finally tote around stuff, and last it'd be a good sub for the colder months.
Old Mar 31, 2011 | 10:48 AM
rpol78's Avatar
Originally Posted by LS1GMCTruck
In the early 80's Camaro's, the Iron Duke 4-cylinder engine was an option. It was rated at 50 mpg in the Camaro. If memory serves, this was with a manuel transmission. As you can imagine, hardly any dealers ordered them. The Duke would be an interesting engine to perform a modern single turbo install on, for even better performance & mileage. I'm sure its been done somewhere/somehow, already.
An then there's Smokey Yunick's version of the "Hot Vapor Induction" Iron Duke HP + Mileage
http://www.legendarycollectorcars.co...clusive-video/
Old Mar 31, 2011 | 11:34 AM
Pocket's Avatar
Rate it at what you want, the duke rarely cracked 20mpg in 3rd gens because it took so much grunt to get the heavy pigs going
Any FYI, hardly any dealers ordered over 70,000 of them. They were popular because brand new they were dirt cheap
A small efficient engine in a small car yields excellent economy which is how the micro cars of the late 80s early 90s gave such great results
Putting a small engine in a large car kills the efficiency because it has to work so hard
Old Mar 31, 2011 | 01:44 PM
Bo185's Avatar
I was talking about adjusting the AFM itself via the tune, to make it stay on longer etc. The AFM is worthless IMO. Especially in the trucks
GM just uses it as gimmick to keep the feds of their *** on MPG increase requirements and for advertisement.
Of course tune the ECM/PCM will give you way more power and even more economy.
Old Apr 1, 2011 | 02:48 AM
rpol78's Avatar
If you're inventive take a look at the Hot Vapor system. From the Banks website on it.
http://www.bankspower.com/techarticl...r-Equals-Power
"The final conclusion is that regardless of whether an engine is normally aspirated or supercharged, gas or diesel, the cooler the intake air, the better. Usually.
Now comes the really interesting part of this article that raises all the questions. Twenty years ago, the late, great racing mechanic and inventor Henry "Smokey" Yunick left the automotive engineers shaking their heads when he invented and patented his hot vapor engine. Based on the familiar four-cycle piston engine concept, instead of cooling the intake air to improve efficiency, he used coolant heat and exhaust waste heat to significantly warm the intake air. The purpose was to fully vaporize the fuel and to make the intake air expand in the intake system to generate positive pressure, like a supercharger. A small turbocharger was used as a "mixer" and as a check valve to prevent the expanding intake air from backflowing out of the intake system. With the heated, pressurized, homogenous mixture, the engine ran at air/fuel ratios considered impossibly lean, such as 22:1, on pump gasoline. The hot vapor engine made incredible power and was highly efficient, responsive, surprisingly emissions clean, and delivered fuel economy of 45-50 MPG in a compact car, and it did it all without computers, smog pumps or catalytic converters. Although initially denounced by the automotive world as a hoax, several prominent SAE engineers later published papers validating Smokey's theories and design. It was no hoax to Smokey. He considered it his greatest achievement. However, the automotive giants had their own designs for increasing fuel economy and controlling emissions, and Smokey's simple and cost-efficient engine package was ignored. Today, Smokey's designs are buried somewhere in the U.S. Patent Office (www.uspto.gov, patent numbers: 4,503,833; 4,592,329; 4,637,365; 4,862,859) awaiting someone to take this technology to the next level. So just when you think you know the rules of how things work, somebody comes along and breaks the rules. It's only fitting that it was Smokey Yunick."
Maybe somebody on the board will take it to the next level. 1.8hp per cubic inch + economy.....Hmmmm....
Old Apr 1, 2011 | 06:38 AM
Paul57's Avatar
Originally Posted by Wimimc
ok i have a 3rd gen Camaro, carb'd 305 with a 700R4 and 3.23 gears. car weighs ~3300
what engine/trans/rear combo would get me ~22-24 mpg city and ~30 or more highway.
^^ or as close to that as possible
i'm open to any GM engine (minus the iron duke). turbo a 4.3L? turbo the 5.0L? a turbo'd ecotec motor from a cobalt?
i'd probably swap in a M6 whichever route i take.
Don't use a 4.3 or 5.0, they aren't nearly as efficient as the new Gen III motors. A 4.8 got about 1 mpg better than the 5.3 before they started doing active fuel management etc. I think they concentrated on the 5.3's first because they are such a huge seller. So, I don't believe the 4.8's had that technology as early...maybe they still don't??? If you are going to run a carb, then a 4.8 with any OD tranny and those gears. I am sure one of the cam gurus can design you a good mileage/torque cam to help, too.
Old Apr 1, 2011 | 07:44 AM
Pocket's Avatar
Tell that wash to the Fiero guys
He actually released several completed engines in Fieros, not a damn one performed AT ALL like he intended. Fiero enthusiasts have decided something was up so they built their own systems modeled off his and not a damn one of those worked either
Much like the 100mpg carb, alot of these ideas you will hear about werent squashed by any corporation, the "inventor" just couldnt figure it out so they patented the half finished concept, called it a miracle and went looking for gullible investors
Smokey did alot of great things, this just wasnt one of them
If you want proven 50mpg, look into the late 80's early 90's micro economy cars. They follow the path of a small efficient engine in a small car and wont apply to a large car like a 3rd gen
Old Apr 1, 2011 | 12:48 PM
rpol78's Avatar
Obviously you're not well read on the topic of the engineering and history of Hot Vapor nor what happened.... Go do your research and then maybe you could add a valid comment.....
From a circle track racer
"That's a matter of record. While his "hot vapor" engine produced an array of combustion efficiency benefits, it would've been (or was believed to have been by the OEM who reviewed his findings at the time) a significant economic step and commitment from then-conventional powerplant technologies. There's no doubt the concept worked. I was present during some of the dyno tests and drove the car. In fact, I recently learned it's still around and functional."
From Hot Rod's follow up article (I read the original article on it back in 1984)
"Eventually, there was a three-cylinder Buick (half a V-6), a Ford project, and a Mopar Omni/Horizon. Every application got more than 45 mpg and made at least 1.8 hp/ci. The Detroit OE boys and nationally certified independent labs verified all the claims and performance figures. It was on the verge of going into production (one application, for the '90 S-10 truck, got very close). Crane Cams was given a license to develop aftermarket retrofit kits. Then everything fell apart.
It was the "not invented here syndrome" rearing its ugly head again. How could a couple of gearhead hot rodders know more than all of Detroit's best engineering talent? By this time, Detroit was committed to the computer, fuel injection, and the catalytic converter. Traditional theory was to get rid of or manage heat; Smokey was channeling heat for improved performance, the exact opposite of conventional engineering science. True, he had allies in Detroit, but his cantankerous personality had also generated plenty of enemies over the decades. The shifting political tides of OE politics eventually left Smokey out in the cold.
The original Fiero was ultimately crushed by Pontiac, which demanded Smokey return the long-term loner when GM pulled the plug on the initial project. Smokey returned the car, but not before removing the entire drivetrain. This is Allard's duplicate Fiero built in 2006 using the original salvaged Smokey drivetrain.Meanwhile, durability concerns led Crane to back off on the boost levels and temperatures for its projected retrofit kits. Smokey's original motors had trick rings, forged pistons, and Carrillo rods, but the retro kits would be bolt-ons for econo four-cylinders. The kit cost kept going up, even as performance declined. Bickering started. In marched the lawyers, and lawsuits inevitably followed. The project collapsed under a pile of recrimination."
Old Apr 1, 2011 | 01:06 PM
Wimimc's Avatar
Wasn't smokey the guy that they thought, or knew he was cheating when racing, but they could never prove it?
Old Apr 1, 2011 | 01:24 PM
  #32
rpol78's Avatar
His most famous car was a '67 chevelle that NASCAR would not let him race. He came up with all kinds of methods to "bend" the rules.
Old Apr 1, 2011 | 02:04 PM
  #33
Pocket's Avatar
He reinvented cheating for motorsports. He really was a pioneer for quite a few things, just not this system. Anyways even if this system did work, it wouldnt be cost effective to the OP. The objective was a cost effective econo setup in a 3rd gen. Stock 305 fits the bill, stock/very mild swap also fit but the benefits will take longer to be effective. An unproven system is not the answer
Old Apr 1, 2011 | 02:36 PM
  #34
rpol78's Avatar
GM 3.8 supercharged 27 mpg highway and 20-21 around town in a grand prix. Mileage + Performance. Hook it up to your 700r4 and be done with it.
Or go buy a good used high mileage econo box - probably cheaper in the long run.
Old Apr 1, 2011 | 02:44 PM
  #35
rpol78's Avatar
What are you basing this on? It's easy to blow stuff out your butt!!!! As a matter of fact I believe I can smell it from here.
And your credentials are???????
Old Apr 1, 2011 | 03:18 PM
  #36
chasgiv3's Avatar
If you want gas mileage then build yourself a lean burn system. A wideband and some programming plus a lot of engineering will get you there. But be carefull you could blow some **** up. Anyway....
If you want a V8 to get great gas mileage in the city then you need to re-learn the way you drive. No stop and go, make it as light as possible, use a manual and shift really early to the point of almost bogging the motor.
Old Apr 1, 2011 | 03:23 PM
  #37
chasgiv3's Avatar
Oh and if you do happen to try to do some lean burn programming on your car make sure you don't have CATs on them. I believe the lean burn will destroy them after a while.
Old Apr 1, 2011 | 03:28 PM
  #38
welldonecj7's Avatar
are those A6s common to come by? i dont know if i've ever seen one for sale
the Active Fuel Management, is that the flex fuel? or what the L99s have?
and stock vs stock, or each with equal bolt ons, which would net better mileage a 5.3L or an LS1?
34 in town??
edit: the other thing i have been thinking about was getting a 67-72 C series pick up and doing a swap with mileage in mind. i'd have something for the winter, and also a truck to haul around parts and anything else i need. Although with the truck's weight, i don't know if any build would get me what i want mileagewise, even a few miles per gallon under my goal.
No not 34 what the op stated he would like to get in the city
