4l60e help
Old Apr 9, 2011 | 08:07 PM
Project66impala's Avatar
Default 4l60e help
I did a 2000 ls1 conversion and everything works except when I put it in gear and I drive it wont shift and if I put it in any other gear it will drive. So basically it will not shift into any gear and stays in 1st
Old Apr 10, 2011 | 12:38 AM
pdsq98gt's Avatar
You need to hook up a high quality scanner that can see trans data. See if it's commanding a shift. If it is, you may have a bad shift solenoid or sticking valve in the valve body. If it's not commanding a shift, you have a tuning problem. Also make sure your vss works.
Old Apr 10, 2011 | 06:54 AM
aknovaman's Avatar
Wink
Got +12 volts on the pink power lead at trans? There are two pinks so be sure to check the corect one as only one should have power.
