1968 Camaro thinking of going LS
Can he keep the stock 4 speed? Or should he just go T56? Any floor mods.
Best place to buy headers and mount? S&P.
Any cutting to run ac?
Pease let me now what problems arise in installing one of these in 1 gen camaro.
Thxs for your help.
If your going to running standard or 1" setback plates. you can not run the OEM AC compressor in its location, the plates will come into contact it it. I would recommend relocating the compressor to the passenger side head location. (unless you run Early Style BRP plates, then you can notch the frame and it will work out). Some have flipped the plates and mounts to clear.
Go with a T56.. the money you save on gas on trips will pay you back, its going to be $5 a gallon pertty soon !.. you can also run a lower rear gear and still have good mileage.
Ive use Edelbrock swap headers on both of my swap. but they don't make them anymore. S&P, Hooker, and many other make swap heads now. but make sure they are designed to work with your plates.
