VATS bypass module, anyone use it????
I spent the cash, bought HP Tuners and a wide band because I was losing all the smog stuff and I knew I was going to do future upgrades. Money well spent and problem solved.
After having someone almost steal my car (busted the column and had the ignition on)... the VATS system was the only thing that saved it.
since then, ive kept some form of a VATS system on every GM car ive wanted to keep.
Its really easy to retrofit.
Another question about this: how long will the engine stay running if the VATS is not bypassed? Anyone know? I ran the engine only for 10 secs total to test the bypass, hope it works! Video here:
http://www.youtube.com/watch?v=baR8fjrmI5U
by the way, nice job and thanks to the designer... 70 LS1 , I believe.
I'm very interested. I'm doing a 91 corvette swap right now and our systems are very similar.
On a 91 camaro the VATS system is almost standalone.
the key wires go down to a box thats well hidden under the dash.. this box has the starter relay disable in it, and an output wire that sends a square wave signal out to the ECM.
All you have to do is connect that signal wire to the PCM and leave the rest of it alone.
and even if you don't connect it to the PCM, if you leave it there it remains an effective starter disable.
On a 91 camaro the vats system is almost standalone.
The key wires go down to a box thats well hidden under the dash.. This box has the starter relay disable in it, and an output wire that sends a square wave signal out to the ecm.
All you have to do is connect that signal wire to the pcm and leave the rest of it alone.
And even if you don't connect it to the pcm, if you leave it there it remains an effective starter disable.
Thanks
you can blame vats if the motor catches, starts and nearly immediately dies, no 5-10 seconds, it fires, catches, turns a few times and dies. I could hold my foot on the pedal and it would cleanly rev up and then die
