Some Dumb Questions
I have the jeep fuel tank and pump. I know it doesn't make quite enough pressure, but i was wondering if the pressure should be ample enough for it to at least run at idle.
I don't have the front o2 sensors hooked up yet. The motor should still run without these hooked up? just rough?
I think what happens is when the key cycles on the jeep pump is told by jeep computer to pump fuel for the standard amount of time. I turn over engine cranks and runs, but the gmc computer is not telling the jeep fuel pump to keep pumping so it runs till it drains the rails and no gas equals no fun.
I am going to buy a fuel pressure gauge in the morning and test rail pressure and see what is going on with it, but my best guess is the wire going to the jeep pump from the chevy harness must not be on the right wire or is not sending the proper signal for the jeep pump to keep sending fuel.
Recap:
1. Jeep PSI to low to run 5.3 at idle
2. Front O2 sensors air fuel mixture won't let it stay running
3. Jeep/5.3 wiring not communicating to keep fuel flowing.
I am hopeful that it is 2 or 3 but figured i would ask some experts. If you want to hear it run search matthewsavery on you tube and there is a video of it running today
