LS integrated wiring?
Thanks
J.
Very few companies or individuals will offer a fully integrated harness because that requires an extensive working knowledge of both the donor vehicle and the car your swapping into
If you're looking to purchase a harness thats already setup, then contact www.psiconversion.com, they have prebuilt harnesses available and will build you a custom harness if need be.
If you're looking for an 'off the shelf' all-in-one wiring harness that includes everything to wire your Nova, I don't think you're going to find one for the reason Pocket mentioned. The closest you're going to get is a combination of a couple of harnesses (one for the engine-trans management and the other for the body of the Nova) from Painless, American Autowire, etc. If you don't want to or have the skills to build the harness yourself the other option you have is to take the car with everything installed to a wiring specialist and let him build you a complete harness, you would soon realize the cost of a Painless kit is a bargain.
JMO,
Mike
On '60s-'70s Novas or Camaros, it can be made quite sanitary, just eliminate the OEM alternator connections and pick up the body supply lead at the point the alternator battery lead is connected.
Thanks again.
J.
Your Source for LSX Conversion Parts!
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
This did take a lot of time, but if you like wiring & electronics it can be a fun project. I probably had more fun doing this harness than any other part of the car... but I'm a little weird, too.
Thanks
J.
Ebay Store
