Making the swap
Old Apr 21, 2011 | 10:43 AM
lethal bird's Avatar
Default Making the swap
Well im finally about to make the swap. Ive been gathering part for a little while now, and the lt1 is driving me insane so i have completely decided to get the lt1 running, pulling it, and selling it and swapping in my lq9 that has been in the shop for about 6 months now. So it looks like ill be spending some more time over here for a while. This will be my first swap so please dont bash to hard on my future noob questions.
Old Apr 21, 2011 | 05:20 PM
LSCha0s's Avatar
What are your plans for the LQ9?I wish I had a solid rear axle.
Old Apr 21, 2011 | 08:24 PM
the_merv's Avatar
Veteran: Air Force
Right up your alley..
https://ls1tech.com/forums/conversio...to-95-z28.html
Old Apr 21, 2011 | 09:01 PM
Originally Posted by the_merv
Yea ive looked at that thread soooo many times and so many others. It will take a little while cause im still in college and work 2 jobs but ill get it together. My plans are going to be a budget mild bolt on, cam only for now. I still haven't quite decided what cam i will be using yet but it will be on the mild side because ill be using the stock heads.
Old Apr 27, 2011 | 10:53 AM
Ok so ive just about got everything i need.
Stock shortblock LQ9
Stock heads
ls1 intake
ls1 fuel rails
36lb injectors
ls7 lifters
torquer v.2 cam or CheaTR cam
ls2 timing chain
stock ported tb
tsp ported and shimmed ls6 oil pump
ls1 windage tray, pick up, and oil pan
ls1 harness
ls1 fuel filter/regulator
stock coils
zo6 maf
ls1 front accessories
powerbond pulley
still dont know what springs ill be using, and will all the stock lq9 sensors work or will i need ls1 sensors? Anything that you guys can pin point i need or im doing something wrong or i have the wrong parts?
Old Apr 27, 2011 | 10:54 AM
Keep in mind im on a pretty tight budget. Im about to get the lt1 running and im going to pull it, sell it and the pcm, harness, and finish button up the rest of it.
Old Apr 28, 2011 | 11:21 PM
So am i on the right track?
