HEADERS that will fit my 1965 Chevelle LS2
Old Apr 22, 2011 | 09:37 AM
Chief25's Avatar
Default HEADERS that will fit my 1965 Chevelle LS2
New member looking for HEADERS that will fit my 1965 Chevelle LS2/6.0 Eng.
Thanks
Old Apr 23, 2011 | 08:51 AM
TurboLark's Avatar
Dougs, Hooker, Headman, Kooks...will just depend on what motor mounts, oi pan, accesories you are running.
Old Apr 23, 2011 | 11:34 AM
71ANTICARB's Avatar
There is a ton of builds and threads that will produce the information you seek. Search chevelle headers and check out the A-body sticky.
Old Apr 24, 2011 | 07:31 AM
oldgoat69's Avatar
Dougs fit the engine well and provide great ground clearance. Plan on fabbing or modifying your trans crossmember to provide clearance.
Old Apr 24, 2011 | 10:01 AM
Jimbo1367's Avatar
Originally Posted by oldgoat69
Dougs fit the engine well and provide great ground clearance. Plan on fabbing or modifying your trans crossmember to provide clearance.__________________
Old Goat 69
The best advice I have ever heard:
Never pet a burning dog!
LOL. I like your advice
Old Apr 24, 2011 | 11:38 AM
icemanrd19's Avatar
turbolark suggested hookers but from what i read their quality went down hill fast. Check out protouring.com also for some info
Old Apr 24, 2011 | 05:49 PM
t72ss402's Avatar
I ordered these off of ebay. I have not mounted them yet, but the they look to be really good quality. All the welds look really good.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
I am going to put then in my 72 Chevelle.
Tim.
Old May 6, 2011 | 03:44 PM
Chief25's Avatar
Thanks for all the info
Old May 7, 2011 | 12:37 PM
kevinciaran's Avatar
just a note about the hookers... I just finished installing them last weekend and the thing I noticed is not ground clearance but floor clearance. I mounted my engine a bit higher than the hooker mounts probably would to get adequate clearance for the oil pan to tie rod (f-body pan). The passenger side mount is right up on the floor. Instead of lowering the engine I chose to clearance the floor. Anyway, if the engine is back far enough and not too high, these fit the 65 chevelle well. You can see the floor clearance in the pic.
i also fitted them with a 3 bolt flange because I didn't really like the slip fit idea,
the other one shows the stock spark plugs bump into the primary tube...they may work with some trimming or else I will have to find some smaller ones.
Attached Thumbnails HEADERS that will fit my 1965 Chevelle LS2-ls1-342-large-.jpg   HEADERS that will fit my 1965 Chevelle LS2-ls1-345-large-.jpg
Old May 8, 2011 | 01:43 PM
tommycomfort's Avatar
I also had trouble with the hookers on our 66. I used their mounts and still had to clearance the floor on the passenger side. I solved the spark plug wire problem by ordering a set from Mast and they fit great.
Tom
Old May 8, 2011 | 02:50 PM
baker163's Avatar
I used the stepped header's from edelbrock and the worked great,I did however use there motor mount plates too!
Old May 8, 2011 | 03:38 PM
speedtigger's Avatar
Old School Heavy
I used the Doug's headers on my 65 Skylark. There is no way to use them with the Edelbrock adapter mounts which are pretty much the same as the Doug's and the Hooker mounts. The engine needed to be up and back an inch to get them to work and get the steering to clear the oil pan, so I made custom mounts. The clearance problems on my build for the Doug's headers is the passenger floor board and the drivers frame rail. With the custom motor mount frame stands, I was able to locate the engine in the perfect position to make it work, but the engine location has to be just perfect. It is pretty much a game to get the engine high enough to clear the pan while still allowing the headers adequate clearance.
Old Jun 10, 2011 | 09:23 AM
Chief25's Avatar
Help,, looking for Info on LS2 swap on a 65 chevelle. Looking for Friends end or around detroit, who can help with Info or I can get a look at your swap. Thanks
Old Jun 10, 2011 | 10:15 AM
Jimbo1367's Avatar
Get BBC headers and weld on LS1 flanges. You can put the collecter where you want it.
Old Jun 10, 2011 | 11:48 AM
Project GatTagO's Avatar
The port spacing on a BBC and an LSx engine are nowhere close to being in the same place. NOt to mention the fact that a BBC is much taller, so even if you were to get the port flange to work, the headers would hang way too low when bolted to an LSx engine.
Andrew
Old Jun 10, 2011 | 04:09 PM
Jimbo1367's Avatar
Andrew
The BBC ports aren't as close as the 351W, but it can work without too much of a problem. I got a cheap set of headers and can align the back cylinders and shorten the spacing for the rest to make it work. The collecter location is about perfect. The main purpose of using header like this is most of the design work is done. It will fit the body style. BTW. I have BBC frame stands and cheap 1"setback plates.
