need an alternator bracket
Old Apr 28, 2011 | 08:36 PM
xcr00's Avatar
Default need an alternator bracket
did some seareching but cant find what i need. give you a lil info. i put a body of a 71 vwbug on a s10 frame with a 5.3 ls. the alternator is to high and it hits the hood. i need to know what bracket system i can use to lower the alternator. i have also eliminated the power steering so i no longer need the pump. i dont want to make it if i dont have to. can i use something from another car or does anybody produce something i can use.
Old Apr 30, 2011 | 08:14 PM
LSCha0s's Avatar
The F-body bracket mounts it low on the drivers side.You could shim iy out 3/4" to match the rest of your truck accessories.
Old May 1, 2011 | 04:00 AM
garys 68's Avatar
First off, you have got to post some pics.
As for a lower alternator with truck spacingd....
https://ls1tech.com/forums/conversio...rive-done.html
Old May 1, 2011 | 06:52 AM
71ANTICARB's Avatar
F-body or Corvette or gto will all be lower than the trucks.
