Stand alone harness question
Old Apr 30, 2011 | 08:43 PM
Foxbody4.8L's Avatar
Default Stand alone harness question
I'm using LT1swap.com to build a stand alone harness out of a 2005 truck drive by wire harness and I see they put all the pink wires to a separate fuse box.. but where is all 8 of the pink injector power wires going.. dont see how you only use 4 fuses for about 15 wires??
any help would be great!
Old Apr 30, 2011 | 08:49 PM
TS99SS147's Avatar
If you were to follow the pinks from the injectors you would find that they are spliced together in the harness. This is why you end up with less pinks that you have to have fuses for.
Old Apr 30, 2011 | 08:54 PM
they all went to the C2 plug that went in the trucks fuse box..
http://www.lt1swap.com/pictures/step6%20%28Large%29.jpg
see
Old May 1, 2011 | 09:43 AM
Pocket's Avatar
Trucks have independent injector fuse wires. They get paired at the fuseblock connector and paired once more at the fuse for one per bank. It wont hurt anything to splice all 4 injectors and the coil IGN wire to one and then send it to a single fuse point for each bank
Most delphi harnesses do the splice vs run individual to save on wire
Old May 1, 2011 | 10:04 AM
Mudweizer's Avatar
INJ A 15 Amp fuse feeds Ignition coil 1,3,5, and 7 and 1,3,5, and 7 injectors.
INJ B 15 Amp fuse feeds Ignition coil 2,4,6, and 8 and 2,4,6, and 8 injectors.
Fuses hot on run/start.
Info from a 2002 Chevy Tahoe 5.3L on AllData.
Old May 1, 2011 | 03:40 PM
ok thanks guys.. i thought each bank would get paired together.. just wasn't sure.. I appreciate the help
