water pumps
Is the offset in the balancer or are there different offsets in the water pump pulley? Thanks, Scott!
There are different inlet/outlet locations on the pumps. Which can cause interferance with other Accessoires and Throttle Body, etc.
What front accessory setup do you currently have and what changes are you planning to make or problem areas to work around ?
anybody know which truck does that...or does the new camaro?(if it is the same as truck stuff)
Tony
http://www.atiracing.com/products/da...ts/damserp.htm
