5.3l swap problems
Old May 8, 2011 | 12:51 AM
Jayhill's Avatar
Default 5.3l swap problems
Put a 05 5.3l lm7 in a 84 2door caprice. Bought a harness and computer from PSI. Computer was programed. After completing everything engine just turns but will not crank. Got gas pumping to fuel rails. Got a noid light an checked injector plugs for signal from harness. Pulled plugs one by one and checked for spark. Any info is greatly appreciated
Old May 8, 2011 | 01:33 AM
Jayhill's Avatar
Checked old plugs changed out an tried to start it. Still no start bought new plugs an tried again. Pulled plugs an noticed gas on them.
Old May 8, 2011 | 02:46 AM
Gee101's Avatar
Check with who ever programmed the pcm to make sure they disabled vats. If you know forsure they disabled vats then put a scanner on it and check for codes.
Old May 8, 2011 | 08:58 AM
Old Geezer's Avatar
How long has the engine been sitting?? A chance that the injs are stuck is good, if it's a junk yard engine that's had gas in the rails for an extended time...
Old May 8, 2011 | 10:19 AM
the_merv's Avatar
Veteran: Air Force
VATS disables the Injectors, not the spark.
Check Rail Pressure when the pump is priming, check all grounds for the Coil Packs.
Old May 8, 2011 | 10:29 AM
the_merv's Avatar
Veteran: Air Force
Post some pics up if you can..I have a friend with a 87 2-door Caprice I'm tryin to get to convert to LS..
Old May 8, 2011 | 10:51 AM
deuce4935's Avatar
Are you sure the pcm is getting a constant 12 volts during the cranking cycle? Double check all grounds, (engine to frame, frame to body, battery to frame). Good to see another box body Caprice being converted to LSx power. I've been driving my 80' Caprice Landau(98' LS1/4l60e, z06 topend) for 3 years now and man its a blast everytime I get behind the wheel. Pm me if you need some pointers.
Old May 9, 2011 | 11:31 AM
psiconversion's Avatar
LS1Tech Sponsor
Jay,
Since I dont have your name I cant pull the work order to verify, so have three questions for you below
1. What MAF sensor are you using?
2. What intake manifold/tb set up are you using?
3. Is check engine light hooked up?
Thanks.
Jon
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old May 11, 2011 | 11:54 PM
Jayhill's Avatar
25179711 maf sensor, truck intake with dbw, no check engine wire is not wired in. Jerome Hill
Old May 12, 2011 | 12:03 AM
itsslow98's Avatar
auto or m6? possible the PCM doesnt recognize the car is in park/neutral so it wont let the car start?
Old May 12, 2011 | 07:28 AM
Old Geezer's Avatar
Lightbulb Suggest..
you complete the install.. No way to tell wtf is going on without the diagnostic link being installed.....
