will the ls1 alternator fit the 5.3 bracket?
Old May 12, 2011 | 05:12 PM
gwf7782's Avatar
Default will the ls1 alternator fit the 5.3 bracket?
I got an ls1 harness and a 5.3 motor . the ls1 has the 1 wire pigtail and the 5.3 has a 3 wire pigtail. How can i rewire the truck alternator to fit the 1 wire ls1 harness or will a 1 wire ls1 alternator fit the truck bracket. thanks for your help/
Old May 12, 2011 | 06:45 PM
gvnick's Avatar
Fits the bracket perfect, and the pulley is the same.
The Camaro alternator only takes one wire to the L pin. You should be able to just clip the other two wires from your harness...
Old May 12, 2011 | 07:18 PM
gwf7782's Avatar
my f-body harness only has one wire to the 4 terminal plug, will that 1 wire work with the 5.3 alternator.
Old May 12, 2011 | 08:12 PM
chevelle598bb's Avatar
Yes the one wire from the LS1 harness will work with the truck alternator. Just get a truck alternator pigtail. Replace the brown wire on the truck alternator pigtail with the red generator wire from the LS1 harness. Get rid of the other wires on the truck generator pigtail and you will be good to go.
Old May 12, 2011 | 09:05 PM
gwf7782's Avatar
ok cool thanks for the help.
