LS2 Harness
Old May 16, 2011 | 04:05 AM
Speedrat's Avatar
Default LS2 Harness
I have an LS2 out of a 2008 VE GTS Commodore. I do not have PCM or harness. Will the GM kit part number 19166568 work on this engine? It has a grey crank sensor which I believe is a 58x reluctor wheel.
Thanks
Old May 16, 2011 | 04:15 PM
ishmael's Avatar
Give Pace a call to find out for certain. There are very few companies that do a harness and computer for the 58x but is that PCM non-programmable? You may not want that one if you can't program it later. PSI can make you that harness and set you up with a ECM and TCU for less.
Old May 16, 2011 | 10:49 PM
Blevinator's Avatar
PCM is programmable with that kit. I had mine custom programmed! Same kit
Old May 17, 2011 | 06:41 AM
psiconversion's Avatar
LS1Tech Sponsor
Yes, we have a kit that directly competes with the LS2/LS3 kit you have listed. Includes all components. PM me for details.
Jon
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
