Lq9 wiring!!! Help!!!!
Old May 16, 2011 | 02:49 PM
Redboy4457's Avatar
Default Lq9 wiring!!! Help!!!!
Ok, heres the deal.. I have searched and searched and there are a millions threads out there I KNOW!! But every thread seems to be to complicated or it seems to alter off into there swaps and comments from other people. I cant take it anymore all its doing is confusing me.
So for a little information, I have an '84 Silverado. I have an 2005 LQ9 with a bout 150,000 miles on it with the original Harness, TAC Module and pedal. I recently picked up a 4L80e automatic trans.
I realize I have to get an adaptor harness to hook the 4L80 up to the LQ9, and that I will have to swap the trans tunes in HPTUNERS. I don't care about air conditioning or Emissions. All I care about is putting it in my truck and having it all run correctly and reliably. With that, I was wondering what needed to be done to the wiring harness. This is probably were everyone is like search and this goes back to the first part, of where I do and have been all the time, but its always for 5.3's or the wiring for 2001's or 2002's and even them it seems like they always stray from the subject. SO I was really hoping and asking what I need to do to my stock LQ9 harness to get it running. Diagrams??? Just a straight answer?? More simple the better obviously, but my dad will be doing the harness while I'm at school, and he just wants to send it out for 500, but obviously being in College I don't have 500 lol... SO a simple route to take here would be a huge help...
PLEASE!!!!
Old May 16, 2011 | 02:52 PM
devlmaycry's Avatar
Ok, for your harness go to lt1swap and look there. They have a harness diagram for an 04 or 05 lq9 (should be the same) it shows you in highlighted colors what pins to remove and which ones need to be used with your stock harness. It's not too complicated, just time consuming. I just did my 2003 LQ9 for my 240sx. Took me a couple days to do it all.
Hope this helps.
Old May 17, 2011 | 06:50 AM
psiconversion's Avatar
LS1Tech Sponsor
We have brand new harnesses for that application for $500. PM us if interested.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old May 17, 2011 | 07:28 AM
Old Geezer's Avatar
PSI... Whats with the "index" that comes up with a clik on your website??
Old May 17, 2011 | 11:21 AM
LS1Tech Sponsor
Currently revamping entire shopping cart and all images. Taking a little longer than we wanted but good things come to those who wait (or so they say). Going to have much more information on the updated site as well in terms of free schematics and stuff to download. Sorry for any inconvenience.
Jon
__________________
Ebay Store
Old May 27, 2011 | 08:41 PM
Redboy4457's Avatar
If I am running an electronic trans "4L80" do I still delete the trans wires in the blue and green connectors??
Old May 28, 2011 | 12:07 AM
G-Body's Avatar
sawzall wielding director
If you are still using an auto trans, you will need the transmission wires. To go from a 60e to 80e you just need to re-task a couple wires. Check out this thread https://ls1tech.com/forums/conversio...ompatible.html.
Old May 28, 2011 | 12:48 AM
dHud's Avatar
I have a psi conversion harness, been out of the box but never installed, and I must say it looks to be top notch!
Old May 28, 2011 | 09:11 PM
Redboy4457's Avatar
I bet it looks good.. If I had the money I would think about buying one. But I do like being able to say I did it myself. And getting farther in the harness and like the a/c wires, and like the cruise I cut from the PCM connectors and I run them back to the plugs, do I just cut them from the plugs?? And keep the plugs?? Little help please.. Thanks
Old Sep 13, 2024 | 07:21 AM
SSS78's Avatar
Default Lq9 to 78 blazer swap
[QUOTE=Redboy4457;14920213]Ok, heres the deal.. I have searched and searched and there are a millions threads out there I KNOW!! But every thread seems to be to complicated or it seems to alter off into there swaps and comments from other people. I cant take it anymore all its doing is confusing me.
PLEASE!!!![/did you ever get the answer on the LQ9 swap? I am doing the same thing and want to make sure I’m following the right wiring diagram. QUOTE]
Old Sep 13, 2024 | 08:29 AM
Old Buzzard's Avatar
Maybe try reading and following up on post #2 from 13 yrs ago.....
"Ok, for your harness go to lt1swap and look there. They have a harness diagram for an 04 or 05 lq9 (should be the same) it shows you in highlighted colors what pins to remove and which ones need to be used with your stock harness. It's not too complicated, just time consuming.
Old Sep 13, 2024 | 09:50 AM
SSS78's Avatar
well, that’s my problem when I go in there and look I cannot find that I’ve looked quite a bit and I don’t wanna follow the wrong wiring one I have looked quite a bit
Old Sep 13, 2024 | 09:55 AM
SSS78's Avatar
I’m not even sure if I’m posting a reply right here my problem is I’ve looked all over and I can’t find it on a LQ9. Not sure if that makes a difference. I’m assuming it does.
Old Sep 13, 2024 | 12:33 PM
jrs396's Avatar
Redboy has not posted in 12 years, zombie thread
