fuelrail R&R
Old May 22, 2011 | 11:27 AM
Jimbo1367's Avatar
Default fuelrail R&R
Do I need to replace injector o rings if I flip the fuelrail 180*?
thanks,
JIm
Old May 22, 2011 | 12:16 PM
350SS's Avatar
i haven't had to but it helps to squirt a little wd40 or something to help free the o-ring from the manifold so they don't get damaged during removal...squirt a little and let it soak in then after removing them check to make sure no cracking or damage to the o-rings
Old May 22, 2011 | 01:49 PM
gofastwclass's Avatar
I never have, just be careful taking them out.
Old May 22, 2011 | 07:57 PM
rotor vs. piston's Avatar
Same ^^^, if anything put some lube on them when you re-install so they pinch.
Old May 23, 2011 | 02:54 PM
bczee's Avatar
Inspect them.. If in qestion. always replace. Cheaper now that later.. and what everyone else said..
