HELP with Codes on LS1 swap
0352 Ingition Coil B Primary/Secondary Circuit
0358 Ingition Coil H Primary/Secondary Circuit
These codes just come on when you drive the car HARD and then after that is starts Missing but you can Stop and reset the Computer and it stops Missing and runs GREAT but as soon as you Stand on it Hard the Codes come Back on not sure Whats up do i have a Bad Coil?
All so my Harness came Wired for 2 fans but i am only running 1 fan and it keeps giving me a 0481 Fan 2 Control Circuit Code How can i keep it from giving me this Code can i just Ground that wire so it think its Grounding a Relay when its just realy grounding to the Body?
THANKS for any Help guys.
