need wiring help
Old Feb 24, 2004 | 08:39 PM
69c4x11's Avatar
Arrow need wiring help
please help im currently wiring my 69 camaro,using a speartech engine harness and a centech wiring harness.i cant figure out how to get my wiper motor to work correctly. it is a stock wiper motor(new). it has a light blue wire that connects to one spade,then a black w/yellow stripe,then a black wire on the other 2 spades. the kicker is that there are a light blue,blue,black wire that comes off the switch.can anyone help me connect the dots .thanks
Old Feb 25, 2004 | 09:05 PM
67ls1CamaroProject's Avatar
On my 67 the blue needs to have 12 volts with the key on. The black wire is the ground. Those switches are notorious for improper grounding between the switch body and the dash. So, a good fix is to wire a ground wire from the switch body to the dash somewhere. Not familar with a centech wiring harness. But, the Speartech one would have nothing to do with the wipers.
