need headers for my custom swap
Old May 25, 2011 | 04:07 PM
pugz's Avatar
Default need headers for my custom swap
looking for some glockhuggers for my 5.3l that im swapping into a fully custom built nissan pathfinder. its a full custom frame and i dont have alot of room. what are the best and tightest fitting ones out there?
heres some pics of my build so far.
http://photosbypugz.smugmug.com/Truc...05707471_UAaZL
brands and/or part numbers would help greatly
thanks
Old May 25, 2011 | 04:15 PM
pugz's Avatar
ohh yeah... its a 06 5.3 with a carb swap and a 700r4
Old May 25, 2011 | 06:06 PM
2xLS3's Avatar
I didn't see any pictures of the motor in the frame in your collection to see what the clearnces are, but if your interested in using manifolds, the 2010 Camaro manifolds fit pretty close to the block and the flow decently
Old May 26, 2011 | 01:53 PM
sikbrik's Avatar
I'd look at www.sandersonheaders.com but I haven't used any of their LSx stuff. Great quality on gen1 sbc headers, though, and tight fitting.
Old May 26, 2011 | 08:45 PM
52 Rat's Avatar
I went with the Hooker Super Comp block hugger. They fit tight.
Old May 27, 2011 | 05:51 PM
Clyde65's Avatar
I used the Sanderson CSLS1 swap shorties for my swap, I like them very much and they have done great.
Old May 27, 2011 | 10:10 PM
2Aspire's Avatar
If there is not a solution that fits your needs already available then you could use these guys..
http://www.stainlessheaders.com/customheaders
Not cheap when you consider the cost of off the shelf headers but when you start to investigate what it costs to have custom headers made in just mild steel you will agree that this is a good deal for a custom stainless header..
I used them because I wanted a stainless header that would work with my column shift SS but also had other provisions that I wanted.. Plug clearance..Bolt on collectors, Ease of install/removal...O2bungs
Again..not anywhere near as cheap as an off the shelf solution but If you come up empty they are awesome people to work with and they nailed my design the first time..
Old May 27, 2011 | 10:57 PM
Mike52's Avatar
Pugz, I used the Sanderson block hugger headers for my swap because they tucked in the tightest according to all the specs I found. Here is a post with pics of my Sandersons. Hope this helps.
Old May 30, 2011 | 08:56 AM
pugz's Avatar
DO ALL LS1-6 HEADERS FIT ALL LS MOTORS? FOR INSTANCE, WOULD SOME SHORTYS FROM A 6.2l NEW CAMARO BOLT UP RIGHT TO MY 5.3?
Old May 30, 2011 | 11:15 AM
Jimbo1367's Avatar
2Aspire,
Great link. TYVM!
Old May 30, 2011 | 11:19 AM
LS3owner1's Avatar
nice headers, love the mock up tubes
Old May 31, 2011 | 12:39 PM
2Aspire's Avatar
4.8, 5.3, 5.7, 6.0, 6.2, 7.0L, Same bolt pattern..
2Aspire,
Great link. TYVM!
Your Welcome!
Thanks! They send you the correct flanges, a set of collectors and elbows.. Then you buy the PVC pipe to cut. It was a lot of work but well worth it..
