Inline fuel pump, Wire to existing fuel pump relay?
Old Feb 26, 2004 | 12:27 AM
Flyman's Avatar
Default Inline fuel pump, Wire to existing fuel pump relay?
I need to install my new walbro inline fuel pump and I think i will need to just wire it to the existing relay that runs my intank fuel pump, so they both turn at the same time, is this correct?
Thanks
Old Feb 26, 2004 | 06:58 AM
crainholio's Avatar
You'll nearly double the amperage draw on that poor circuit, so be sure it's up to the task. Walbro 255 pumps draw ~9 amps at 60psi, not sure what your in-tank pump pulls.
I'd add a separate relay for the inline pump. www.racetronix.com sells a kit including relay and wire to do this.
