s10 lm7 swap
Old Jun 11, 2011 | 09:22 PM
zx2ner25's Avatar
Restricted User
Default s10 lm7 swap
just like the title says, but my question is how do i pass emissions in illinois... i only have to pass an obdII monitors test, no real inspection for anything 95 and older... how would i go about getting a 2000 to pass? would i just have my tuner tune out the codes? please advise quickly, planning on buying the truck this week
Old Jun 12, 2011 | 01:47 AM
Black98s10's Avatar
Can you reregister the truck in a county that doesn't have emissions? I told the dmv that my truck is kept in baraboo, wi. and my mailing address is Milwaukee. I don't have to my truck for emissions.
Old Jun 12, 2011 | 02:15 AM
zx2ner25's Avatar
Restricted User
no, pretty much everywhere in illinois has emmissions, and pretty much everyone that i know is in my general area, so its not like i can register it to a friends house or anything
Old Jun 12, 2011 | 01:42 PM
mjls1's Avatar
Active Streak: 30 Days
I'm in north west illinois and no testing here
Old Jun 12, 2011 | 09:21 PM
Msilver's Avatar
most of illinois doesn't have emissions. Chicago has emissions, central illinois and southern illinois don't.
Old Jun 12, 2011 | 11:17 PM
zx2ner25's Avatar
Restricted User
hmm, thanks, thats news to me, i need to move for sure, but for the time being does anyone have any help?
Old Jun 16, 2011 | 12:45 PM
tommyd2006's Avatar
A good tuner can make it pass no prob.
Old Jun 16, 2011 | 04:48 PM
zx2ner25's Avatar
Restricted User
What if I were to remove the codes with hp tuners, then the pcm wouldn't know to look for those systems, which would mean system pass which would mean emmissions pass
Old Jun 16, 2011 | 08:28 PM
2xLS3's Avatar
You need to set the codes to "Do Not Report"
Old Jun 16, 2011 | 09:15 PM
philntx's Avatar
My 2000 S10 Blazer ( 6 liter, CNC heads, TR blower cam, Long tubes, dual cats, all emissions equipment hooked up, 4 O2 sensors, no codes, readiness flags all show ready) has passed every time in Dallas. (Same testing regime as Cook County) Passed OBD2 and sniffer. Wouldn't make it in California because of the long tubes.
Old Jun 16, 2011 | 09:40 PM
zx2ner25's Avatar
Restricted User
Huh, good to know, I just found a 95 s10 extended cab for 1200 so emissions testing wont be a problem, but more on the hptuners... if I don't install any emission equipment and say do not report I'll have no check engine light correct?
Old Jun 16, 2011 | 09:55 PM
2xLS3's Avatar
95 is a bastard year, most tuning packages don't support it
Old Jun 17, 2011 | 01:11 AM
zx2ner25's Avatar
Restricted User
That I understand, but it I use a 99 silverado engine ALDL connector or pcm I should be tuning a 99 rather than a 95. Right?
Old Jun 17, 2011 | 04:52 AM
2xLS3's Avatar
Correct, if you're using a 99 pcm and OS, but what did you do for the ABS, since most of those bastard year PCM controlled the ABS or didn't your truck have it?
Old Jun 17, 2011 | 05:29 AM
zx2ner25's Avatar
Restricted User
yes the truck has abs, but as http://www.currentperformance.com/s10wir.html states (summarized from what i remembered) that you will use both computers, the stock s10 pcm will control things like abs & Cruise control, the lm7 pcm will control everything else. also, it comes with a second aldl connector that ill just run to inside the cab so i can tune and read codes from the comfort of some Corbeau Seats
