I'm one problem away from driving!!!
Old Jun 17, 2011 | 09:30 PM
GNCLONE's Avatar
Default I'm one problem away from driving!!!
I just finished my LQ9 swap and it is almost ready to go! I have solved a bunch of problems, but am stuck at the shifter cable.
The shifter and cable are from an 80s Monte Carlo SS (which was never offered with a 700) and I have bolted my 4L60 to the LQ9. FYI a 4L60 is basically a 700R4.
The problem is that the cable is too short and looks like it won't work with the bracket on the trans anyway.
Any help is appreciated.
Old Jun 17, 2011 | 09:47 PM
xpndbl3's Avatar
shifter and cable from a f-body swapped in Or any aftermarket shifter of your choice that works with 4 speeds trans.
Old Jun 17, 2011 | 11:37 PM
914turboford's Avatar
I just solved a similar issue on my 1984 C4. I used a '02 Camaro 4l60e. The corvette shifter/cable wouldn't travel far enough to shift into all gears. I modified the shifter cable so that it would travel farther. Don't know if you can do the same.
Old Jun 18, 2011 | 05:29 AM
GNCLONE's Avatar
I don't mind getting a new cable, but I want to get what will work and not throw money away
Old Jun 18, 2011 | 07:37 PM
mice13's Avatar
I used the shifter and cable from a 98 T/A..works fine!
