240 sx 4.8
I have a 89 s13 and am thinking of going w/ a 4.8 LR4 from a truck since they are dirt cheap and going to probably build it to a 5.3
Was thinking of using a Daft Install kit, will this work? not sure if the mount holes on the 4.8 are the same as the LS1 also i believe a t56 will bolt w/ pilot bearing installed of course but not 100% From my research it seems I will have to use f-body accessories and intake but how about the PCM and Harness do I need an LS1 harness and computer or can I use the 4.8 stuff. Also are the mounting for the headers the same as the LS1's or will I need diff heads? Any info and or confirmation would be much appreciated!
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
I am using truck motor mounts on an LS1 so I would say that they are the same
The exhaust and intake are interchangable
I beleive the truck engine is missing a hole for one of the bellhousing bolts but it is not a big deal
Fbody accessories will be needed to clear the hood
Use the truck computer and harness
Truck engines will take a T56 no problem, but the F-body alternator bracket will require you to drill and tap your block for a hole that isn't there on the truck engines. LS1 intake/fuel rails will bolt right up, but the injector plugs are different so you will have to solder different injector pigtails onto your harness. Motor mounts are all the same bolt pattern.
I would add up all your swap needs and see how much more it would be for an LS1. Then go from there. I would at least look at a 5.3 or LQ4 all are fairly cheap. There's an alum version of the 5.3 or something too I hear.
