Stock in dash tach not reading correctly
Old Jun 21, 2011 | 02:23 PM
kwkrat2's Avatar
Default Stock in dash tach not reading correctly
I got my 69 Camaro running with the LS-2 and am trying to use the factory in dash Tach, but it seems that the ECM must give off a different pulse, because the RPM's seem way low. Has anyone else ran into this and is there a cure to run the factory tach?
Old Jun 21, 2011 | 02:25 PM
LS1MCSS's Avatar
Most likely the factory pcm is still set for a 4 cylinder signal. Are the readings about half of what they should be?
Old Jun 21, 2011 | 02:27 PM
kwkrat2's Avatar
1/2 would probably be accurate. Wouldn't the PCM be set for the GTO tach?
Old Jun 21, 2011 | 02:41 PM
LS1MCSS's Avatar
Don't ask me why GM decided to have the pcm's send out a 4 cylinder tach signal, but they did.
Old Jun 21, 2011 | 03:07 PM
kwkrat2's Avatar
So is this a re-program issue?
Old Jun 21, 2011 | 09:55 PM
LS1MCSS's Avatar
Just have the person that did the programming to set the tach output to 8 cylinder.
