Fuel Pressure Reg??
Old Jun 26, 2011 | 10:13 AM
MillsMotorvation's Avatar
Default Fuel Pressure Reg??
Hi, My car is Idling rich, do I need a FPR to turn the FP down? I dont have tunning eqp yet sent the PCM off to get VATs removed. So whats the best way to do the FPR on a LQ4 truck intake? Doing a turbo insatll in a 81TA. Fuel PSI is at 60 most of the time, and seem to drop when I open the throttle.
Old Jun 26, 2011 | 01:31 PM
tsnow678's Avatar
From what I have read 60psi should be fine. It might be in the tune that is causing the rich condition. Is it throwing any codes (check engine light)?
Old Jun 27, 2011 | 07:42 AM
Old Geezer's Avatar
I used a pair of Summit rails, some Fragola fittings and hose, to install the Aeromotive regulator on my LQ/truck intake. [No turbo.]
I made my own rail mounts.
As for turning the Fp down....Find out what's causing the rich condition. Turning the FP down will screw w/ the IFR.
