fuel for fox
Old Jun 29, 2011 | 02:40 AM
ironic's Avatar
Default fuel for fox
i have a fox body im putting a ls1 in and the fox is just a shell no fuel stuff wat so ever.. i was first gonna order a fuel system complete from glenns performance.. but since im runing the ls1 can i order the complete system then just change the fittings for the fuel rails? wat should i do??
Old Jun 29, 2011 | 03:42 AM
RATBOX's Avatar
Just get a stock tank, sender w/a Walbro 255 and the Russell fittings to fit the sender to 6an. Connect that and a return to a vette regulator, mount the regulator where the factory ford fuel filter would've been and then run your "fuel" out line from the regulator up to your rail. Good to 500whp.
Search around on here, lots of fox builds that'll answer all your questions in triplicate.
The Glen's setup is nice, if you call them and tell them what you're doing he'll set you up with the right parts for the conversion. Get out your check book though!
