No spark.
Old Jun 30, 2011 | 11:04 PM
lteone's Avatar
Default No spark.
Have no Spark on a LS1 swap in a g-body. The harness and VATS delete was done by Wait4me performance. I have verified power when the key is in the Start postion. I have verified injector pulsing with Noid light, and the fuel pump is coming on when cranking. I have power and ground too the coils.
pulled a plug and get no spark when cranking.
There is a plug for the oil pressure sensor that is unhooked, the owner wanted to use a mech. gauge.
any suggestions, figured i would call Wait4me tommorrow but thought i would post.
thanks Scott
Old Jun 30, 2011 | 11:10 PM
bad6as's Avatar
There are fuse's. One for each side coils. Check thoes? Grounds on back of cylinder head?
Old Jun 30, 2011 | 11:20 PM
lteone's Avatar
well there is no fuses in the harness this has.. also only one ground that has been hooked up. Thank you for the ideas!
Old Jun 30, 2011 | 11:54 PM
mice13's Avatar
Make sure your 12v lead to pcm is getting power when cranking. It might have power when key is forward, but not when cranking. It happend to me, no spark when cranking either. Switched wire to another spot on fuse panel and fired right up!
Old Jul 1, 2011 | 05:58 AM
bad6as's Avatar
That's true, hapened to me as well. If I turn the key to far it kills the power to the pcm.
Old Jul 1, 2011 | 09:07 AM
psiconversion's Avatar
LS1Tech Sponsor
Do you have a tach signal when cranking either through a scanner or the vehicle tachometer?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
