Switching carb to FI
Old Jul 14, 2011 | 09:30 AM
LSJM1's Avatar
Default Switching carb to FI
Do I need a vss signal if I'm doing a bare bones setup and I have a turbo 400 trans
Old Jul 14, 2011 | 01:25 PM
bczee's Avatar
You can get away with not having it, but it would help a lot when your slowing down and stopping, many have had issue of the engine dying or almost dying on coming to a stop.
The PCM can control the engine idle better if it know how fast the car is going.
Old Jul 14, 2011 | 04:52 PM
Mudweizer's Avatar
Check this site out for vss signal per speedometer cable:
http://www.dakotadigital.com/index.c...rod/prd109.htm
Old Jul 14, 2011 | 08:26 PM
LSJM1's Avatar
Thanks when I built my turbo 400 I changed the output shaft and it takes a press on speedo gear instead of the plastic gear and clip that holds it
I might try it without a signal maybe keep the idle screw turned up a little
I still have stock cam and when I do put a cam it will be a small one so strong vacuum might help it from stalling
