Fuel Line connector question
I could change the 5/16 connector easy enough.
Thoughts?
You could use a short piece of hard line with the barb on it, then use a Compression fitting on the hardline. Most fitting vendors make a compression fitting that is threaded with what ever size you need. (NPT or AN) ?
You can get a junk piece of the tubing with the barbon it from a yard or Doman markets short pieces with barbs on it. (most parts stores can get Doman products, ask to see the catalog).
https://ls1tech.com/forums/conversio...swap-faqs.html
http://www.summitracing.com/parts/RUS-640860/
http://www.summitracing.com/parts/RUS-640850/
Taken from:
http://www.fullsizechevy.com/forum/g...bs-trucks.html
more info here on AN lines:
http://www.smokemup.com/tech/an_thread_sizes.php
