Need help fast guys! LS2 in a Chevelle
Old Jul 22, 2011 | 05:12 PM
jeff70's Avatar
Default Need help fast guys! LS2 in a Chevelle
I do not know much about LS engines. The car is a 71 Chevelle with a 05 GTO lS2.
I exited of the freeway this morning when coming to the stop light the car just died, it turns over but will not fire.
Where should I start to look first?
Old Jul 22, 2011 | 05:16 PM
350SS's Avatar
fuel pressure
Old Jul 22, 2011 | 05:18 PM
jeff70's Avatar
If were fuel pressure, wouldn't it still try to fire or spit and sputter?
Old Jul 22, 2011 | 06:27 PM
Project GatTagO's Avatar
Not necessarily. Time to get a gauge on the fuel rail.
Can you hear the fuel pump prime when you first turn the key?
Honestly, from your symptoms it could be about a dozen different things.
Andrew
Old Jul 22, 2011 | 10:11 PM
jeff70's Avatar
Thanks for the quick response guys.
I figured it out I went back to the basics spark and fuel the car has a Ricks tank and I could not hear the pump so I started looking for fuses turns out a fuse had blown, as of yet I don't know why. I got to say though the guys that did this install cut some corners on the stuff that most people don't see like the wiring under the dash.
